lawriebuck's avatar
lawriebuck
RN104 'Fan System in enclosure Internal speed is below threshold. (0 rpm)' message
Hey all,
This morning on my RN104 I got the error message "Fan System in enclosure Internal speed is below threshold. (0 rpm)", However the fan is running flat out, sounding almost like a hair dryer. No adjustment to the fan speed settings in the Admin page seem to make any difference.
Recent changes: 12 days ago I installed a new drive after a drive became degraded. I then upgraded from 6.10.2 to 6.10.3.
A reboot makes no difference.
I am running 6.10.3 firmware.
Does anyone have any suggestions as to what the issue may be and a possible fix?
  • It sounds like the tachometer signal from the fan isn't working.  Obviously, use warranty replacement if that's an option.  Otherwise, hopefully, it's the fan itself and a fairly easy fix by replacing it.  If it's the monitor circuit, there's nothing you can do save add a "pad" that lowers the fan speed (but does nothing to correct the NAS's ability to monitor or control the speed).
  • Marc_V's avatar
    Marc_V
    NETGEAR Employee Retired
    lawriebuck
    Welcome to the Community!
    Do you notice if there's a change in the temp of the NAS itself? or the drives might be running hot.
    If you still have warranty on your RN104, which is 3 years it is best to contact Support so they can issue you RMA if needed.
    HTH
    • lawriebuck's avatar
      lawriebuck
      Hey Marc_V
      Thank you for your reply.
      Both drives are maintaining a steady 19 to 20 degrees C (68 degrees F).
      The CPU temp is a pretty steady 34 degrees C (91 degrees F).
      I no longer have warranty on this product so I am happy to do whatever is economically viable to repair it.
      Cheers,
      Lawrence
      lawriebuck
      Hello Sandshark
      Thanks for your suggestion!
      Out of warranty unfortunately.
      I was hoping it might be a software issue with a software fix, but I'm happy to change out the fan to see if that will fix it.
      Can you suggest any other troubleshooting I could do to help me to determine if it is a software or hardware issue?
      Lawrence
      • Sandshark's avatar
        Sandshark
        Sensei
        If you have any old fan you can connect temporarilly to see if it then senses the RPM, that would be good.  Otherwise, I don't know of anything without an oscilloscope or frequency counter.
ProSupport for Business
