Dewdman42
Aug 01, 2026Virtuoso
System: V+12 voltage in enclosure Internal is out of spec.
I started getting the following warning messages last night to my logs on my Ultra2 which is functioning as a backup to my other primary NAS: System: V+12 voltage in enclosure Internal is out of...
Dewdman42
Aug 05, 2026Virtuoso
for sure its not a bad idea to spend $10 for a new brick to at least eliminate that possibility. Thanks for that idea.
Are you aware of any command line cmds or utilities I can use to detect the current voltage? I can't find it displayed anywhere in the frontview web interface...just logs from a few days ago.
