tommyhackett
Apr 04, 2019Aspirant
System volume root usage (/dev/md0) at 100%
I have recently began getting the error message in logs “Volume: System volume root's usage is 100%. This condition should not occur under normal conditions. Contact technical support.”
Some se...
tommyhackett
Apr 05, 2019Aspirant
Hi, thanks for the response. I did a little more searching just after I made the post and think I'm in a good place now.
You're right, there were more of the chunk files (1461 written to the root!) and removing them appears to have solved my problem.
After doing that, I think I'm ok with root looking like:
root@TXHReadyNAS:~# cd /
root@TXHReadyNAS:/# ls -1
1
apps
bin
boot
data
dev
etc
frontview
home
init-stream0.m4s
init-stream1.m4s
lib
lost+found
media
mnt
opt
proc
root
run
sbin
selinux
srv
sys
tmp
usr
var
root@TXHReadyNAS:/# df -h
Filesystem Size Used Avail Use% Mounted on
udev 10M 4.0K 10M 1% /dev
/dev/md0 3.7G 649M 2.9G 19% /
tmpfs 1009M 8.0K 1009M 1% /dev/shm
tmpfs 1009M 468K 1009M 1% /run
tmpfs 505M 1000K 504M 1% /run/lock
tmpfs 1009M 0 1009M 0% /sys/fs/cgroup
/dev/md127 1.9T 729G 1.2T 40% /data
/dev/md127 1.9T 729G 1.2T 40% /home
/dev/md127 1.9T 729G 1.2T 40% /apps
I'm really not sure what could have caused Plex to behave this way initially, perhaps I did something wrong when installing/updating it some time. Any way, I have removed and reinstalled Plex using the GUI. No signs yet that it is writing unwanted stuff to the root again, but I will have to keep an eye on it I guess.
Apr 05, 2019Guru - Experienced User
You should probably remove these two also, as they were also left there by plex.
init-stream0.m4s init-stream1.m4s
- tommyhackettApr 05, 2019Aspirant
Ah ok, I have done that now, thanks!
