viperhansa
Oct 12, 2015Virtuoso
System volume 'root' usage is 83 %. . Please contact technical support.
Hi all.
I got everything to work and suddenly i get this error: System volume 'root' usage is 83 %. This condition should not occur in normal conditions. Please contact technical support.
I have seached the forums and tried the different suggestions made but i cannot find the culprit..
I need some assistance with this please. I do not want to start over all again.
if i do df -h in root i get:
root@Hoa-Nas-Pro:~# pwd
/root
root@Hoa-Nas-Pro:~# df -h
Filesystem Size Used Avail Use% Mounted on
rootfs 4.0G 2.9G 876M 77% /
tmpfs 10M 4.0K 10M 1% /dev
/dev/md0 4.0G 2.9G 876M 77% /
tmpfs 2.0G 48K 2.0G 1% /dev/shm
tmpfs 2.0G 3.8M 2.0G 1% /run
tmpfs 2.0G 0 2.0G 0% /sys/fs/cgroup
tmpfs 2.0G 0 2.0G 0% /media
/dev/md/data-0 14T 5.5T 8.2T 41% /data
/dev/md/data-0 14T 5.5T 8.2T 41% /home
/dev/md/data-0 14T 5.5T 8.2T 41% /apps
/dev/md/data-0 14T 5.5T 8.2T 41% /var/ftp/Audio
/dev/md/data-0 14T 5.5T 8.2T 41% /var/ftp/FtpFtpFtp
/dev/md/data-0 14T 5.5T 8.2T 41% /var/ftp/ieexkb
/dev/md/data-0 14T 5.5T 8.2T 41% /var/ftp/media
/dev/md/data-0 14T 5.5T 8.2T 41% /var/ftp/Movies
/dev/md/data-0 14T 5.5T 8.2T 41% /var/ftp/home
/dev/md/data-0 14T 5.5T 8.2T 41% /run/nfs4/data/Audio
/dev/md/data-0 14T 5.5T 8.2T 41% /run/nfs4/data/media
/dev/md/data-0 14T 5.5T 8.2T 41% /run/nfs4/home
tmpfs 4.0K 0 4.0K 0% /data/ieexkb/snapshot
tmpfs 4.0K 0 4.0K 0% /var/ftp/ieexkb/snapshot
/dev/md/data-0 14T 5.5T 8.2T 41% /data/ieexkb/snapshot/c_2015_10_10__00_00_28
/dev/md/data-0 14T 5.5T 8.2T 41% /var/ftp/ieexkb/snapshot/c_2015_10_10__00_00_28
/dev/md/data-0 14T 5.5T 8.2T 41% /data/ieexkb/snapshot/m_151010
/dev/md/data-0 14T 5.5T 8.2T 41% /var/ftp/ieexkb/snapshot/m_151010
root@Hoa-Nas-Pro:~#
I read in some post that Logitech Media Server could make a mess so i tried to uninstall it. No Success! Same error that some other user wrote in the forum about.
Since i run 6.3.5 on a legacy nas my options with support is.... well.... non existing?
I can offer full access whenever to the server if that helps. With vpn. or if you prefer whatever other way of conneting.
I REALLY need support on this.
1: find the reason why root is almost full
2: get rid of Logitech Media server. (Minor priority)
Regards
Hans
btw, my other posts about cron and such are solved. i will update them to that status.
Success! :smileyvery-happy:
Found this: datadir = /var/lib/mysql
Changed to: datadir = /data/mysql
Stopped mysql server.
Copied all content in location 1 to location 2.
Made sure that all rights where correct.
Deleted all content in location 1.
Started Mysql server and checked df -h:
After moving SQL databases from var/lib/mysql:
root@Hoa-Nas-Pro:/data# df -h
rootfs 4.0G 464M 3.2G 13% /
/dev/md0 4.0G 464M 3.2G 13% /
tmpfs 2.0G 0 2.0G 0% /dev/shm
tmpfs 2.0G 6.0M 2.0G 1% /run
/dev/md/data-0 14T 1.8G 14T 1% /data
/dev/md/data-0 14T 1.8G 14T 1% /home
/dev/md/data-0 14T 1.8G 14T 1% /apps
/dev/md/data-0 14T 1.8G 14T 1% /run/nfs4/home
/dev/md/data-0 14T 1.8G 14T 1% /var/ftp/home
/dev/md/data-0 14T 1.8G 14T 1% /var/ftp/ieexkbBack to 13% from 54% again and all seems to be working.
- viperhansaVirtuoso
Hi all.
Update:
In root i have a folder called run, in that folder there is a folder called nfs4 that contains aprox 1gb of various data.
If i do df -h that folder is not on the os partition..
/dev/md/data-0 14T 5.5T 8.2T 40% /run/nfs4/data/Audio
/dev/md/data-0 14T 5.5T 8.2T 40% /run/nfs4/data/media
/dev/md/data-0 14T 5.5T 8.2T 40% /run/nfs4/homeRight?
Cannot find whats filling /dev/md0 4.0G 2.8G 940M 75% /
Having a hard time understanding this...... :smileyfrustrated::smileyindifferent:
Did a complete FACTORY reset and started over with a df -h after each step:
Only activated SSH:
rootfs 4.0G 311M 3.4G 9% /
/dev/md0 4.0G 311M 3.4G 9% /
tmpfs 2.0G 5.9M 2.0G 1% /run
/dev/md/data-0 14T 36M 14T 1% /data
/dev/md/data-0 14T 36M 14T 1% /home
/dev/md/data-0 14T 36M 14T 1% /apps
/dev/md/data-0 14T 36M 14T 1% /run/nfs4/homeAfter PHP5:
rootfs 4.0G 333M 3.3G 10% /
/dev/md0 4.0G 333M 3.3G 10% /
/dev/md/data-0 14T 36M 14T 1% /run/nfs4/homeAfter mysql:
rootfs 4.0G 513M 3.2G 14% /
/dev/md0 4.0G 513M 3.2G 14% /
/dev/md/data-0 14T 36M 14T 1% /run/nfs4/homeAfter PHPMyadmin:
rootfs 4.0G 498M 3.2G 14% /
/dev/md0 4.0G 498M 3.2G 14% /
/dev/md/data-0 14T 61M 14T 1% /data
/dev/md/data-0 14T 61M 14T 1% /home
/dev/md/data-0 14T 61M 14T 1% /apps
/dev/md/data-0 14T 61M 14T 1% /run/nfs4/home
/dev/md/data-0 14T 61M 14T 1% /var/ftp/homeAfter importing my mysql DB (285mb):
root@Hoa-Nas-Pro:/home/admin# df -h
rootfs 4.0G 1.9G 1.8G 52% /
/dev/md0 4.0G 1.9G 1.8G 52% /
/dev/md/data-0 14T 340M 14T 1% /data
/dev/md/data-0 14T 340M 14T 1% /home
/dev/md/data-0 14T 340M 14T 1% /apps
/dev/md/data-0 14T 340M 14T 1% /run/nfs4/home
/dev/md/data-0 14T 340M 14T 1% /var/ftp/home
/dev/md/data-0 14T 340M 14T 1% /var/ftp/ieexkbIt seems like its the sql database tha eats up the space.
Is this normal?
Can i move the mysql database to my data drives?
