CEBLTD
May 12, 2021Tutor
System volume root's usage is 90%.
Dear All After an extensive search on here i am at a loss. I know this is an error that come up very often it seems. No solutions have worked for me yet Put the latest firmware in and error i...
- May 20, 2021
Dear All
All wlerts have stopped after the reboot, so its sorted.
Thanks to everybody who gave me a reply
closing this off as solved
Regards Patrick
mdgm
May 12, 2021Virtuoso
A full 4GB root volume can have a huge variety of different causes. clamav is not the problem here.
Post the output of these commands:
# df -h # df -i # mount --bind / /mnt # du -csh /mnt/*
May 12, 2021Guru - Experienced User
Also, let us know what firmware you are running.
FWIW, ClamAV hasn't been supported on the RN104 for quite some time now.
