CEBLTD
May 12, 2021Tutor
System volume root's usage is 90%.
Dear All After an extensive search on here i am at a loss. I know this is an error that come up very often it seems. No solutions have worked for me yet Put the latest firmware in and error i...
- May 20, 2021
Dear All
All wlerts have stopped after the reboot, so its sorted.
Thanks to everybody who gave me a reply
closing this off as solved
Regards Patrick
CEBLTD
May 13, 2021Tutor
Hi All
Thanks for the reply, my first reply went lost on the voids of the interweb!
So i seem to have solved it, found a 2 gig log file in apps, logging a php error from 2015 to date! I cleaned that up prayed it will work.
Everything is till working as it should but here are the commands as you wanted.
first
root@CEB-NAS:~# df -h
Filesystem Size Used Avail Use% Mounted on
udev 10M 4.0K 10M 1% /dev
/dev/md0 4.0G 3.5G 218M 95% /
tmpfs 249M 0 249M 0% /dev/shm
tmpfs 249M 540K 248M 1% /run
tmpfs 125M 4.6M 120M 4% /run/lock
tmpfs 249M 0 249M 0% /sys/fs/cgroup
/dev/md126 1.9T 1.3T 573G 70% /NAS-DATA
/dev/md127 1.9T 23G 1.8T 2% /BACKUP_DISK
tmpfs 4.0K 0 4.0K 0% /NAS-DATA/CEB-DATA/snapshot
/dev/md126 1.9T 1.3T 573G 70% /NAS-DATA/CEB-DATA/snapshot/c_2021_03_20__ 00_00_57
/dev/md126 1.9T 1.3T 573G 70% /NAS-DATA/CEB-DATA/snapshot/c_2021_03_27__ 00_00_33
/dev/md126 1.9T 1.3T 573G 70% /NAS-DATA/CEB-DATA/snapshot/c_2021_04_03__ 00_00_34
/dev/md126 1.9T 1.3T 573G 70% /NAS-DATA/CEB-DATA/snapshot/c_2021_04_10__ 00_00_24
/dev/md126 1.9T 1.3T 573G 70% /NAS-DATA/CEB-DATA/snapshot/c_2021_04_17__ 00_01_02
/dev/md126 1.9T 1.3T 573G 70% /NAS-DATA/CEB-DATA/snapshot/c_2021_04_24__ 00_00_55
/dev/md126 1.9T 1.3T 573G 70% /NAS-DATA/CEB-DATA/snapshot/c_2021_05_01__ 00_00_36
/dev/md126 1.9T 1.3T 573G 70% /NAS-DATA/CEB-DATA/snapshot/c_2021_05_08__ 00_00_28
root@CEB-NAS:~#
second
root@CEB-NAS:~# df -i
Filesystem Inodes IUsed IFree IUse% Mounted on
udev 63127 448 62679 1% /dev
/dev/md0 65536 17768 47768 28% /
tmpfs 63582 1 63581 1% /dev/shm
tmpfs 63582 609 62973 1% /run
tmpfs 63582 29 63553 1% /run/lock
tmpfs 63582 9 63573 1% /sys/fs/cgroup
/dev/md126 0 0 0 - /NAS-DATA
/dev/md127 0 0 0 - /BACKUP_DISK
tmpfs 63582 9 63573 1% /NAS-DATA/CEB-DATA/snapshot
/dev/md126 0 0 0 - /NAS-DATA/CEB-DATA/snapshot/c_2021_03_20__00_00_57
/dev/md126 0 0 0 - /NAS-DATA/CEB-DATA/snapshot/c_2021_03_27__00_00_33
/dev/md126 0 0 0 - /NAS-DATA/CEB-DATA/snapshot/c_2021_04_03__00_00_34
/dev/md126 0 0 0 - /NAS-DATA/CEB-DATA/snapshot/c_2021_04_10__00_00_24
/dev/md126 0 0 0 - /NAS-DATA/CEB-DATA/snapshot/c_2021_04_17__00_01_02
/dev/md126 0 0 0 - /NAS-DATA/CEB-DATA/snapshot/c_2021_04_24__00_00_55
/dev/md126 0 0 0 - /NAS-DATA/CEB-DATA/snapshot/c_2021_05_01__00_00_36
/dev/md126 0 0 0 - /NAS-DATA/CEB-DATA/snapshot/c_2021_05_08__00_00_28
root@CEB-NAS:~#
Mount and last cmd
root@CEB-NAS:~# du -csh /mnt/*
780K /mnt/apps
4.0K /mnt/BACKUP_DISK
6.0M /mnt/bin
4.0K /mnt/boot
2.8M /mnt/data
12K /mnt/dev
11M /mnt/etc
31M /mnt/frontview
4.0K /mnt/home
28M /mnt/lib
16K /mnt/lost+found
4.0K /mnt/media
4.0K /mnt/mnt
4.0K /mnt/NAS-DATA
6.2M /mnt/opt
4.0K /mnt/proc
28K /mnt/root
8.0K /mnt/run
11M /mnt/sbin
4.0K /mnt/selinux
4.0K /mnt/srv
4.0K /mnt/sys
44K /mnt/tmp
387M /mnt/usr
1.1G /mnt/var
1.5G total
root@CEB-NAS:~#
Let me know
Regards Patrick
May 15, 2021Guru - Experienced User
They got trapped by the automatic spam filter. Periodically the mods check the filter, and manually release the false positives.
Looking at the details you posted, it appears to be fine now. The apps folder is normally a mount point to the data volume, so if you remount the root to /mnt, the apps folder should be totally empty.
