CEBLTD
May 12, 2021Tutor
System volume root's usage is 90%.
Dear All After an extensive search on here i am at a loss. I know this is an error that come up very often it seems. No solutions have worked for me yet Put the latest firmware in and error i...
- May 20, 2021
Dear All
All wlerts have stopped after the reboot, so its sorted.
Thanks to everybody who gave me a reply
closing this off as solved
Regards Patrick
mdgm
May 17, 2021Virtuoso
# du -csh /mnt/* 1.1G /mnt/var 1.5G total
This suggests the problem is in /var. So you could do e.g.
# du -csh /mnt/var/*
and so forth until you find some big files e.g. some big log files.
If in doubt, ask whether something is something you should empty or remove.
If the anti-virus service is still running you should stop and disable that service. Maybe I was wrong and there could be some huge anti-virus related files still there.
CEBLTD
May 17, 2021Tutor
Hi Thanks for the reply
unfortunately i cannot spot anything abnormal
removed some *.old log files but rather small in size
I have no idea why i keep getting the message to be honest
Regards Patrick
- mdgmMay 17, 2021Virtuoso
Have you checked if the problem is still present after a reboot?
