Irish_John
May 12, 2019Aspirant
System volume root's usage is 96%. This condition should not occur under normal conditions
Im running 6.10 and have the above issue - still. So 6.10 is not the solution to the problem. It does noty help that the posting are all closed off with that being panacea. I expect when whatever it ...
Irish_John
May 13, 2019Aspirant
So a minute is a lifetime - 48 hours or is it days, months, can't remember now, but deafening silence from Netgear was apparent.
SSH'd in and deleted all the anti-virus files.
Problem gone, so is Netgear as a potential candidate for work NAS tertiary storage. Thanks to those who took time to comment.
bedlam1
May 13, 2019Prodigy
Irish_John at the end of the day a 100 series ReadyNAS is an entry level NAS predominantly designed/intended for home use.
You were given options/solutions to get you out of your predicament (by other ReadyNAS Users on this forum) which you scoffed at, prefering to expect Netgear to drop everything and rush to your aid - that was never going to happen sadly for an entry level user.
Once our forum users helped you out (with solutions) you then targeted "Netgear as a potential candidate for work NAS tertiary storage", you need to dig much deeper into your wallet for that and invest in hard/software to support your needs and a sustainable data recovery strategy plan
- Irish_JohnMay 13, 2019Aspirant
Yawn...nighty night, are you and your ego allowed out this late?
I wont be replying to whatever further idiocy you will be compelled to write..but go ahead, knock yourself out.
- bedlam1May 13, 2019Prodigy
Irish_John Thank you for that
I also will not respond further except to say that your mentality has now been revealed, I doubt you will get much future help on this forum
