Rottenweiler
Jul 02, 2017Guide
Temperature Graph Error - Period Year
RNDP6000v2 Runing 6.7.4 Noticed a thrumming/variable fan noise coming from one of my RNDP6000, so investigated to find the original CPU fan is failing (Crown AGE08015B12V) (Still under hardware war...
Jul 02, 2017Guru - Experienced User
My RN526x isn't doing that (though it is running 6.8.0-T54)
- RottenweilerJul 02, 2017Guide
Oddly it isn't ALL of my RNP units either??? (I have three; two are hardware similar, one is a RNP Business, slightly older?)
ALL three are still on 6.7.4
On MyNetgear they are noted as:
ReadyNASRNDP6000v2 AFFECTED
ReadyNASRNDP6000v2 OCCASIONALLY
ReadyNASRNDP6000 NOT (so far)
The second v2 unit only does it SOME of the time when I select or change the PERIOD selection?
(IE occasionally the graph displays correctly)
The older unit does NOT seem to do it?
Must be an odd combination of hardware and software?
I assumed it was a browser issue but it is not? Seen in all three browsers.
I took a screenshot but don't see a way to post it?
- StephenBJul 02, 2017Guru - Experienced User
There is an insert image icon in the rich text toolbar (normally immediately to the right of the hyperlink icon).
But you do need to be an established poster before it shows up - I don't know exactly how many posts it takes.
Another option is to put it in cloud storage somewhere and post a link.
Must not yet be worthy...
I've been an established LURKer for years...
