Confuciusofesse
Jul 22, 2021Aspirant
Test posting
I've posted twice in the last few days but none have shown up in the list of topic etc. So trying with a new login.
ipb_uk
Whoopee it's shown up! So what happened to my other posts? I'll repost with my new login. Regards
ipb_uk
Can anybody tell me what I'm doing wrong? When I try to post my question it never shows up
- ipb_ukJul 22, 2021AspirantHello Everybody,
If I've not given enough detail, please let me know.
The problem is that my rndp6000 is giving me the message "Remove inactive volumes to use the disk. Disk #1,2,3,4,5,6,1,2,3,4,5,6,2,3,5,6.".
Is this retrievable? If so, how?
It's on firmware 6.10.5 Hot fix 1. I can send the logs if needed.
I know a little unix, but haven't used it for sometime. I haven't gone into the box. But, I can do if given the instructions to do so. I'll keep it off until someone tells me it's safe (ish) to start it up.
Thanking you & my very best, Ian.- StephenBJul 22, 2021Guru - Experienced User
It's on firmware 6.10.5 Hot fix 1. I can send the logs if needed.It might be retrievable, depending on what went wrong. rn_enthusiast might be willing to look at your logs, and offer some advice.
- ipb_ukJul 22, 2021AspirantThank You Stephen. It's way past my bedtime, so i'll be retiring for the night.
Regards Ian.
ipb_uk wrote:
Can anybody tell me what I'm doing wrong? When I try to post my question it never shows upThere's an automated spam filter, and something in your post must be triggering it. I just manually released the most recent one. FWIW, someone else will likely release the other two.
- ipb_ukJul 22, 2021AspirantThank very Stephen. I was running out of hair to pullout!
