ribuxavier
Feb 18, 2021Follower
The volume is degraded
I have a ready NAS 6TBx 4 disks, the volume got full and I was not able to delete any data, so I restarted the NAS, after the reboot, not able to open the drives, in web login, it shows that remove i...
Feb 18, 2021Guru - Experienced User
If you have a backup, then you can do a factory default, rebuild the NAS, and restore the files from the backup.
If you don't have a backup, then the best option is to contact paid Netgear support via my.netgear.com, and have them resolve the problem remotely.
Do you know when the volume became degraded?
