swehjo
Jun 29, 2013Guide
Three disk failurs within 15 months on same channel
I have now had three disk failures, february -12, october -12 and now june -13, all on channel three. Seagate disks all three. Normally this channel has also been running slightly hotter than the ...
Jun 30, 2013Guru - Experienced User
Well, it's Seagate that specs the drive operation conditions.
The ST31000528AS operating range is spec'ed 0-60C (http://www.seagate.com/staticfiles/supp ... 36864b.pdf) . Though I don't think that means that Seagate is warranting that sustained high temperature operation won't shorten drive life.
