soulseeker
Oct 08, 2009Aspirant
Thumbs.db error and loosing network contact
Hi there, i got two problems with my readynas: 1. Sometimes, when I try to delete a folder I get an error message that says that explorer still uses the thumbs.db. The folders contain mp3-files ...
dbott67
Oct 08, 2009Guide
Not sure about question 1. Just a guess, but it may be related to OPLOCKS:
viewtopic.php?f=23&t=33796&p=186163#p186135
It *may* be related to this: http://home.bott.ca/webserver/?p=260
As long as the disks are on the HCL, you can use disks with different # of platters, different cache and different manufacturers.
soulseeker wrote:
2. Yesterday I listened to some mp3s while moving and sorting folders, renamed them etc ... and all of a sudden foobar stopped playing and explorer hung while renaming a folder (it seemed the contact to the readynas was lost). After halb a minute it suddenly went on playing and I could use explorer again. This repeated for several times. The readynas log showed no problems afterwards.
soulseeker wrote: PS: and another question - is it a problem to use two different but compatible hds with the same capacity and speed as an x-raid? I currently use samsung, but those disc are currently not available.
