Thresherinc
Oct 21, 2015Aspirant
Time Machine cannot see 2nd Logical Volume
I have an RN104, it has 4x3TB disks in it, configured into 2xRAID 1 volumes. The 2nd Volume was recently added so that I could enable and use Time Machine for my Mac Backups. Here's the rub, whe...
- Oct 22, 2015
Hello Thresherinc,
The /data/home/USER/.timemachine is where Time Machine stores the data, this home folder is always in the default/1st volume of the NAS and can never be moved.
Thresherinc
Oct 23, 2015Aspirant
Bugger!
Thank you for the info, I shall expand the current volume then, I was hoping to keep the volumes seperate, but I guess it's not 'that' important.
Oct 23, 2015Guru - Experienced User
You can also move shares from the first volume to the second.
