konekosan
Mar 08, 2017Initiate
Time Machine failing after updating ReadyNAS 102 to firmware 6.6.1
Hi all, Have had zero problems with my ReadyNAS until two days ago, when I updated firmware to 6.6.1 and right after I had a series of problems: extremely slow load times for the admin page whic...
- Retired_MemberMar 09, 2017
It is probably overwhelmed by the antivrus service. Please disable and see whether performance gets back to normal. Not sure, whether this will address the Time Machine issue, but it might help to get the system more stable.
6.6.1 has issues with antivirus. You might want to keep it disabled until 6.7 finally is available.
Retired_Member
Mar 09, 2017It is probably overwhelmed by the antivrus service. Please disable and see whether performance gets back to normal. Not sure, whether this will address the Time Machine issue, but it might help to get the system more stable.
- konekosanMar 10, 2017Initiate
Thanks! I believe that resolved my immediate issue. After a day of waiting and rebooting, trying to get access to the admin page to make changes, I was able to turn off antivirus and now I can connect right away and my Time Machine backups are running normally.
