towelman
Oct 03, 2012Initiate
time machine OSStatus error 2
Hi I'm having a problem accessing my readynas nv+2 to use as a time machine backup I'm managing to get past the password stage when logging into time machine, whereby i get the error The opera...
marktb1961
Aug 28, 2015Aspirant
I've got this problem too.
Password is accepted so I wonder if it's some problem with permissions.
Wonder if you ever managed to solve it yourself back in 2012!
- mdgm-ntgrAug 28, 2015NETGEAR Employee Retired
Can you send in your logs (see the Sending Logs link in my sig).
- marktb1961Aug 28, 2015Aspirant
@mgdm thanks. I have followed the instructions and emailed my logs.
Your volume is 95% full, which is getting quite full. You would only be able to set a Time Machine quota of about 100GB or so with this much free space which would be too small for what you need one would think.
I can see in diagnostics.log that one of your disks has failed the SMART self-assessment test and a few others have a couple of ATA errors.Do you have a backup?
