sfinn
Jan 06, 2019Guide
Time Machine "selected backup disk does not support the required capabilities"
ReadyNAS204
Firmware 6.9.4 Hotfix 1
Mac OS 10.14.12 on iMac Pro
Time machine backups from my iMac Pro to my ReadyNAS204 began failing shortly after updating my iMac Pro to 10.14.2. I've tri...
Marc_V
Jan 07, 2019NETGEAR Employee Retired
Hi sfinn
Were you able to check the protocol used for the Time Machine backup? Default should be SMB and your updated Mac should also be using SMB.
Have you tried checking if 'Enable Bonjour Service Discovery' and 'Enable Bonjour Time Machine broadcast via SMB' were both checked under Control Panel > File Services > Advanced.
It seems that this issue happened after users update their Macs.
Here are some links that might help
“Time Machine Backup does not support required Time Machine capabilities”
Hope this helps!
Regards
