okulo
Sep 27, 2015Aspirant
Time Machine verification failure (again)
I know this has been discussed before but it seems like a perennial question. The problem occurred with my ReadyNAS Duo every few months and this is the second time it has happened with my RN102 ...
mdgm-ntgr
Jan 08, 2016NETGEAR Employee Retired
Users of Apple's own Time Capsule run into this problem which would strongly indicate the problem is at Apple's end. Their own community shows that Time Capsule users run into this problem.
okulo
Jan 08, 2016Aspirant
mdgm wrote:Users of Apple's own Time Capsule run into this problem which would strongly indicate the problem is at Apple's end. Their own community shows that Time Capsule users run into this problem.
Blame game ping pong.
As an outsider who abandoned ReadyNAS due to this issue (but is still subscribed to this thread), I feel liberated to say exactly what I feel. The Netgear support was so abysmal that I took the RN102 back to the supplier who sold it to me and got a full refund a year after purchase because they could not fathom the problem.
Yes, there are a few cases of this error being displayed from Time Capsule users but having spent three years with this issue on two different ReadyNAS products I can say that the overwhelming majority of problems are using third party equipment and only a handful, if that, are Time Capsule users.
The reported error is generic (I may not be a developer but I was a prolific ResEdit explorer in the 80s and 90s), it does not specify the problem, so could apply to any number of causes so what Time Capsule users and ReadyNAS users are experiencing could be entirely different issues.
What I discovered before I gave up on ReadyNAS is that most third party NAS manufacturers advertise their products as Time Machine 'compatible' rather than Time Machine 'compliant' and that is the dirty little secret which nobody wants to talk about. There are legal discussions which establish the distinction between compatibility and compliance but suffice to say, compatibility does not necessarily mean that it will work - hence the perennial refutation that it's all Apple's fault.
The criteria for Time Machine compliance are laid out in this document:
I am still treading cautiously with my Synology DS213 but what I have noticed is that it seems to have a slightly different approach to creating the backup and when the first backup was made, it took less than half the 36+ hours which my RN102 took.
I might finish by adding that the support on this forum is extremely selective and, I'd venture to suggest, targeted at low hanging fruit. I am not the only person who has played fetch with admins; i.e. asked for more information only to provide it and then be ignored. And I might add that you, mdgm, are the worst offender. And that you, mdgm, gave me advice which bricked my ReadyNAS Duo and then ignored me when I reported the fact back to the thread.
Good luck to anybody who has this problem; you will need it because NOBODY is going help you fix it. NOBODY.
- iangmacJul 02, 2016Tutor
Oh dear.
I am having the same issue backing up to a timemachine share on an RN102, and I have been having the same verification failure.
Given everyone else's experience, i do not have the time to waste on products that do not work; nor am I prepared to not have a backup that I can rely on.
Until the Ready NAS, I have always run 2 alternate stand alone USB disks to ensure I had a level of protection.
Looks like I will need to revert back to this again unless something has advanced over the lat 6 months since the last post.
Backups are not negotiable.
- _frantic_Sep 24, 2016Aspirant
Today I updated my RN 312 from 6.5.1 to 6.5.2.
Some minutes after reboot, my Mac (OS X 10.11.6) reported "Time Machine completed a verification of your backups ... must create a new backup for you.".
- TommyK42Nov 28, 2016Aspirant
I had this problem on my Mac for ages and ages too with the ReadyNAS. I was looking around for another solution, then realised, that I hadn't had this issue for more tahn 2 months now - everything was begin backed up properl over that time.
I suspect that it has something to do with a Mac OS update, not a Netgear firmware update. For your information, My current OS X version is 10.10.5.
Would be interested if it went away for anyone else....
- iangmacNov 28, 2016Tutor
Tommy.
I believe the verification issue is an Apple issue, not a Netgear or other NAS issue.
I purchased a WD Mycloud alternative and it did exactly the same thing.
To solve the issue I turned off the Automated timemachine backup process, and now run all of my timemachine backups manually, and have not had an issue since.
I believe Timemachine cannot cope with a loss of connection to the Netgear, or other NAS system, and basically corrupts itself.
I believe I have caused the issue in the past when I have disconnected my Macbook Pro from the network while it is in the middle of a backup process, not realising the backup process was running. (I probably closed the lid and put it in sleep mode, and when I "woke" my MacBook at a customer site, it could not locate the backup disk, and corrupted itself.)
Obviously this is unacceptable in this day and age, but apple do not seem to have acknowledged the need to fix it.
Running Time machine backups manually has resolved the issue for me as I am in control of when they occur and ensure the NAS is available throughout the backup process.
In my view Time machine is not sophisticated enough to recover from a loss of backup disc connection.
I hope this provides you some assistance.
Message for Apple. You really should engage someone with the necessary expertise to update TimeMachine to incorporate full roll-back recovery when there is a loss connection with the backup system
