DoctorNacho
Dec 04, 2016Follower
Tips: minidlna killing the system performance (fixed)
I use Readynas as my Apple Time Machine backup server. I have noticed that as or recently the backup has just been going slow like molasses. Initially I attributed it to Wi-Fi speed, my Mac, et...
givememynamebak
Mar 12, 2017Luminary
I'm having the same problem causing overheating. Thing is taking 99.8% of CPU and causing my nas to overheat.
I'm using 6.7.0-T180 (Beta 3) on Pro 6.
3716 root 35 15 151484 106036 6072 R 99.8 1.3 113:59.35 minidlnad
Dropbox in Cloud doesn't work, had to use the plugin from ReadyNASXtras.
Discovery page in ReadyCloud doesn't show device once logged in to manage my NAS (have to search by serial number for some reason)
- mdgm-ntgrMar 13, 2017NETGEAR Employee Retired
Any clues in e.g. upnp-av.log or systemd-journal.log as to why it's using so much CPU?
- givememynamebakMar 14, 2017Luminary
I'll have to inspect the logs when I get a moment. I shut off UPNP for now but I suspect it has to do with large libraries.
I also have CPU spikes of 75-85C when using Sabnzb and it's repairing & extracting. Never had this with OS4... sigh.
- StephenBMar 14, 2017Guru - Experienced User
What OS4 system did you have?
