andyp1
Jan 04, 2013Aspirant
Too slow speeds with Duo V1
I just bought a 2nd hand Duo, and quickly I realized that it wasn't the simple plug'n'play solution I was hoping it to be. After a firmware reset and setup I am stuck with unsatisfactory read/Write sp...
Jan 04, 2013Guru - Experienced User
I suspect you mean megabytes per second? It should do around 20 MB/s, and possibly a bit more. Note that reads from the NAS are faster than writes.
Which Netgear Router do you have? More than likely it doesn't support jumbo frames. Also, are your PC and Macbook running gigabit?
BTW, on 802.11g wifi (54 mbs link speed), you would be maxed out at 2 MB/s, and with 802.11n you're normally maxed out at around 8 MB/s. so those WiFi speeds are as expected
