andyp1
Jan 04, 2013Aspirant
Too slow speeds with Duo V1
I just bought a 2nd hand Duo, and quickly I realized that it wasn't the simple plug'n'play solution I was hoping it to be. After a firmware reset and setup I am stuck with unsatisfactory read/Write sp...
andyp1
The router is netgear cg3000, you can see the specs here http://www.netgear.dk/service-provider/products/routers-and-gateways/cable-gateways/CG3000_CG3100.aspx.
You may even notice that the readynas is included in the network picture at the bottom of the page.
It should be more than capable to handle a faster speed since It can work with 400mbits. However my worry is that the speed is still the same when im conneting the Readynas directly to the computer through a cat-5e cable. By no means it should be slower than USB, and Usb can easily handle 20mb/s?
