andyp1
Jan 04, 2013Aspirant
Too slow speeds with Duo V1
I just bought a 2nd hand Duo, and quickly I realized that it wasn't the simple plug'n'play solution I was hoping it to be. After a firmware reset and setup I am stuck with unsatisfactory read/Write sp...
andyp1
Thanks, the reason i used the old pc was to see whether the problem was on the readynas or my other computers. Obviously it could read 30megabyters per second, so it is definitely capable of handling those speeds, but why am I not seing this performance on the Macbook or on the other devices? Im suspecting that it can only be some software configuration that is reducing the speed, but even when everything is set to standard settings it is still the same speed over again.
