wetenhr
Jul 14, 2014Tutor
Transcoding audio files on NV+v2
I have been trying to use Minimserver/Minimstreamer to transcode stereo audio files on my NV+v2 and stream to my audio players. There has been a drop-out problem with transcoding of 24bit and hig...
mdgm-ntgr
Jul 14, 2014NETGEAR Employee Retired
Yes, both have the same CPU.
You really should be using a NAS with an Intel CPU for what you want to do e.g. the RN312 or RN314.
Are there any differences in services enabled or add-ons running on the two machines?
Have you ever expanded the volume on the NV+ v2?
What is the CPU usage like on each NAS when not using Minimserver/Minimstreamer?
