wetenhr
Jul 14, 2014Tutor
Transcoding audio files on NV+v2
I have been trying to use Minimserver/Minimstreamer to transcode stereo audio files on my NV+v2 and stream to my audio players. There has been a drop-out problem with transcoding of 24bit and hig...
wetenhr
Jul 14, 2014Tutor
Thanks for the reply - appreciated.
I don't think there are any notable differences in services. However the Duo v2 is not mine and I can't go check it right now.
I have expanded the volume. About six months ago I added a fourth drive (four x 2Tb drives, all same model).
CPU usage on NV+v2 is minimal when not actively streaming (but with MinimServer/MinimStreamer enabled. Typically 3% with occasional blips to 15-20%.
It has been suggested I might have an out of date or corrupt Java version, so I'm going to try and update that.
R
EDIT - PROBLEM NOW SOLVED. Turned out the problem was with the Java version I had installed. I updated to Version 7 and the problem has now gone away.
R
