AK471
Sep 22, 2011Aspirant
Transfer speeds on Ultra 4
Hello, I am new to the forum and have just bought a Ultra 4. I was expecting this to be incredibly fast on my network but when accessing media from my HTPC it is very laggy. I thought I would check my...
Sep 23, 2011Guru - Experienced User
I think gigabit ethernet is the only way you'll see > 25 MB/s speeds - if my info on Home Hub 3 is correct, you'd need to add a switch (it only has one gigabit port).
Is the office close to the upstairs room? You could try Ghz wifi. That has shorter range, but has much less interference. If you are close enough, you'd get higher link speeds that 2.4 ghz.
