AK471
Sep 22, 2011Aspirant
Transfer speeds on Ultra 4
Hello, I am new to the forum and have just bought a Ultra 4. I was expecting this to be incredibly fast on my network but when accessing media from my HTPC it is very laggy. I thought I would check my...
Sep 26, 2011Guru - Experienced User
Since the switch needs to buffer the data going out the slower powerline links, you will want a switch that supports 802.3x flow control (pause frames). The unmanaged GS108 doesn't do that, you would either need the more expensive GS108T or the GS508/GS608.
Powerline networking is finicky stuff, when it works its great, but when its not, its horrid...
You could try adding powerline filtering (see http://www.smallnetbuilder.com/lanwan/l ... ine-filter). Some homeplug products have this filtering built in, so if you do replace what you have now, you should probably take that into consideration.
