alaah
Jan 26, 2018Aspirant
Transfer the hard disk from a device of the same type on a device of the same type
Hello I have a problem in the storage device of type 104 and I have another device of the same type Is it possible to transfer the Hardsk from this device to the other device without any problem I ...
Jan 26, 2018Guru - Experienced User
You can power down both OS-6 NAS, then move the disk(s). I recommend preserving slot order.
If the target OS-6 NAS uses an x86 processor, the OS partition will be updated. However, some (likely most) apps won't work.
Also, if the target NAS isn't running the same firmware as the source, then the newest firmware will be applied. That is, if the target NAS has newer firmware in its flash, then the disk OS partition is updated. If the source NAS was running newer firmware, then the target NAS flash is updated from the disk.
- alaahJan 26, 2018Aspirant
Do files get damaged? This is the most important thing for me. The files in my company are damaged
Files are images, files, video files- alaahJan 26, 2018Aspirant
With emphasis on having two devices of the same type and the same model and number RN104
- StephenBJan 26, 2018Guru - Experienced User
Files are images, files, video filesThe migration will not damage files (or change the share configuration, users, etc).
If the volume is already damaged, then migration won't fix it.
- alaahJan 27, 2018Aspirant
I misunderstood the subject I was talking to you
I have a problem with theRN104 ReadyNAS 100 Series 4- Bay
and I was asking you if it is possible to transfer Hadersk in this device to another device of the same type and number without any damage to the files in my purse
