nader_ld
Dec 22, 2016Aspirant
Transferring data takes forever on firmware 4.2.30
Hi, I have recently upgraded my ReadyNAS Ultra 6 firmware to 4.2.30 and installed new hard disks (ST33000650NS Seagate Constellation). Now, when I try to transfer data to my RaidServer through U...
nader_ld
I think they are syncing but not sure how to find that about smart stats.
- mdgm-ntgrDec 22, 2016NETGEAR Employee Retired
Under Status > Health there is a SMART+ button next to each disk to check the SMART stats for that disk.
- nader_ldDec 22, 2016Aspirant
Thanks, I found them. I am not sure how to interpret the info. I have it copied here:
I am sorry, it is lot of lines.
Disk1: Model: ST33000650NS Serial: Firmware: RA61 SMART Attribute Spin Up Time 0 Start Stop Count 1 Reallocated Sector Count 0 Power On Hours 361 Spin Retry Count 0 Power Cycle Count 1 End-to-End Error 0 Reported Uncorrect 0 Command Timeout 0 High Fly Writes 0 Airflow Temperature Cel 43 G-Sense Error Rate 0 Power-Off Retract Count 1 Load Cycle Count 1 Temperature Celsius 43 Current Pending Sector 0 Offline Uncorrectable 0 UDMA CRC Error Count 0 Head Flying Hours 201790448468328 Total LBAs Written 33579340 Total LBAs Read 1532273924 ATA Error Count 0 Disk2: Model: ST33000650NS Serial: Firmware: RA61 SMART Attribute Spin Up Time 0 Start Stop Count 1 Reallocated Sector Count 0 Power On Hours 361 Spin Retry Count 0 Power Cycle Count 1 End-to-End Error 0 Reported Uncorrect 0 Command Timeout 0 High Fly Writes 0 Airflow Temperature Cel 46 G-Sense Error Rate 0 Power-Off Retract Count 1 Load Cycle Count 1 Temperature Celsius 46 Current Pending Sector 0 Offline Uncorrectable 0 UDMA CRC Error Count 0 Head Flying Hours 281414847168873 Total LBAs Written 41879319 Total LBAs Read 1523652448 ATA Error Count 0 Disk3: Model: ST33000650NS Serial: Firmware: RA61 SMART Attribute Spin Up Time 0 Start Stop Count 1 Reallocated Sector Count 0 Power On Hours 361 Spin Retry Count 0 Power Cycle Count 1 End-to-End Error 0 Reported Uncorrect 0 Command Timeout 0 High Fly Writes 0 Airflow Temperature Cel 44 G-Sense Error Rate 0 Power-Off Retract Count 1 Load Cycle Count 1 Temperature Celsius 44 Current Pending Sector 0 Offline Uncorrectable 0 UDMA CRC Error Count 0 Head Flying Hours 205518480081257 Total LBAs Written 41890174 Total LBAs Read 1523533581 ATA Error Count 0 Disk4: Model: ST33000650NS Serial: Firmware: RA61 SMART Attribute Spin Up Time 0 Start Stop Count 1 Reallocated Sector Count 0 Power On Hours 361 Spin Retry Count 0 Power Cycle Count 1 End-to-End Error 0 Reported Uncorrect 0 Command Timeout 0 High Fly Writes 1 Airflow Temperature Cel 41 G-Sense Error Rate 0 Power-Off Retract Count 1 Load Cycle Count 1 Temperature Celsius 41 Current Pending Sector 0 Offline Uncorrectable 0 UDMA CRC Error Count 0 Head Flying Hours 281440616972649 Total LBAs Written 41876225 Total LBAs Read 1523679243 ATA Error Count 0 Disk5: Model: ST33000650NS Serial: Firmware: RA61 SMART Attribute Spin Up Time 0 Start Stop Count 105 Reallocated Sector Count 0 Power On Hours 31977 Spin Retry Count 0 Power Cycle Count 104 End-to-End Error 0 Reported Uncorrect 0 Command Timeout 0 High Fly Writes 0 Airflow Temperature Cel 44 G-Sense Error Rate 0 Power-Off Retract Count 103 Load Cycle Count 105 Temperature Celsius 44 Current Pending Sector 0 Offline Uncorrectable 0 UDMA CRC Error Count 0 Head Flying Hours 64931315612895 Total LBAs Written 2840213924 Total LBAs Read 2093892814 ATA Error Count 0 Disk6: Model: ST33000650NS Serial: Firmware: RA61 SMART Attribute Spin Up Time 0 Start Stop Count 1 Reallocated Sector Count 0 Power On Hours 361 Spin Retry Count 0 Power Cycle Count 1 End-to-End Error 0 Reported Uncorrect 0 Command Timeout 0 High Fly Writes 0 Airflow Temperature Cel 42 G-Sense Error Rate 0 Power-Off Retract Count 1 Load Cycle Count 1 Temperature Celsius 42 Current Pending Sector 0 Offline Uncorrectable 0 UDMA CRC Error Count 0 Head Flying Hours 138306536866153 Total LBAs Written 40828079 Total LBAs Read 1523580199 ATA Error Count 0
Removed the disk serial numbers from your post.
Is the array still syncing?
