kscott00
Oct 14, 2015Aspirant
Transition from ReadyNAS Duo v1 to ReadyNAS 104
I'm getting ready to transition from the Duo v1 to the RN104. I intend to start out with one (1) new 2TB drive in the RN104 and copy the files from the Duo to it. Once the file copy has completed I i...
- Oct 17, 2015
after u destroyed the old volume then click on the x-raid box to disengage x-raid2, after that you may click on first drive and create new volume, create with jbod and u are done for drive 1. as for drive 2 u do the same.
i usually called drive 1 as data1 and drive 2 as data2. u may use any name :-)
cpu8088
Oct 14, 2015Virtuoso
that should work
after u insert the 2 old drives to the new nas immediately u need to destroy whats in the old drives and then enable/create the new volume/array with the existing new drive under x-raid2
