kscott00's avatar
kscott00
Transition from ReadyNAS Duo v1 to ReadyNAS 104
I'm getting ready to transition from the Duo v1 to the RN104. I intend to start out with one (1) new 2TB drive in the RN104 and copy the files from the Duo to it. Once the file copy has completed I i...
  • cpu8088's avatar
    cpu8088
    Oct 17, 2015
    after u destroyed the old volume then click on the x-raid box to disengage x-raid2, after that you may click on first drive and create new volume, create with jbod and u are done for drive 1. as for drive 2 u do the same.
    i usually called drive 1 as data1 and drive 2 as data2. u may use any name :-)
ProSupport for Business
