johntclinton
Sep 04, 2013Aspirant
Troubleshooting firefly on NV+ v2
Hi there, Following mdgm's and others advice (viewtopic.php?f=22&t=67954), I manually set up firefly and it worked successfully for quite some time. I had not used the service for quite some tim...
aks
Nov 01, 2013Virtuoso
I think the 5.3.8 update has overwritten your config file and trashed your settings to a non-working state. I am jumping to this conclusion because mine stopped working about the time of the update from 5.3.7 to 5.3.8.
If you ssh in to the NAS and check /var/log/mt-daapd.log, you'll probably find the database type is not correct (sqlite but it should be sqlite3, plus default paths etc are all reset to useless settings).
