johntclinton
Sep 04, 2013Aspirant
Troubleshooting firefly on NV+ v2
Hi there, Following mdgm's and others advice (viewtopic.php?f=22&t=67954), I manually set up firefly and it worked successfully for quite some time. I had not used the service for quite some tim...
johntclinton
Nov 08, 2013Aspirant
Thanks for suggestion, Tony. I took a look at the log file, but the settings seem to be OK. It is sqlite3 and the paths etc all look OK to my non-expert eye. I still can't connect to the firefly homepage.
Cheers,
John
Cheers,
John
