johntclinton
Sep 04, 2013Aspirant
Troubleshooting firefly on NV+ v2
Hi there, Following mdgm's and others advice (viewtopic.php?f=22&t=67954), I manually set up firefly and it worked successfully for quite some time. I had not used the service for quite some tim...
aks
Nov 09, 2013Virtuoso
Can you copy the log showing a restart. Here's mine:
2013-10-30 12:26:54 (4035a000): Firefly Version svn-1676: Starting with debuglevel 2
2013-10-30 12:26:54 (4035a000): Plugin loaded: daap/svn-1676
2013-10-30 12:26:54 (4035a000): Plugin loaded: rsp/svn-1676
2013-10-30 12:26:54 (4035a000): Plugin loaded: ssc-script/svn-1676
2013-10-30 12:26:54 (4035a000): Starting rendezvous daemon
2013-10-30 12:26:54 (4035a000): Starting signal handler
2013-10-30 12:26:54 (4035a000): Initializing database
2013-10-30 12:26:54 (4035a000): Full reload...
2013-10-30 12:26:55 (4035a000): Starting web server from /usr/share/mt-daapd/admin-root on port 3689
2013-10-30 12:26:55 (4035a000): Registering rendezvous names
2013-10-30 12:26:55 (4035a000): Serving 0 songs. Startup complete in 1 seconds
2013-10-30 12:26:55 (4035a000): Rescanning database
2013-10-30 12:26:56 (4035a000): Starting playlist scan
2013-10-30 12:26:56 (4035a000): Updating playlists
2013-10-30 12:26:56 (4035a000): Scanned 28 songs (was 0) in 1 seconds
