johntclinton
Sep 04, 2013Aspirant
Troubleshooting firefly on NV+ v2
Hi there, Following mdgm's and others advice (viewtopic.php?f=22&t=67954), I manually set up firefly and it worked successfully for quite some time. I had not used the service for quite some tim...
aks
Nov 25, 2013Virtuoso
Hi John, I've been travelling....
A reboot should restart it? Or, from a terminal: service mt-daapd start
Check the 'services' file at /etc/default/services (change the entry DAAP=0 to DAAP=1) to enable the Firefly service. Is it enabled?
