johntclinton
Sep 04, 2013Aspirant
Troubleshooting firefly on NV+ v2
Hi there, Following mdgm's and others advice (viewtopic.php?f=22&t=67954), I manually set up firefly and it worked successfully for quite some time. I had not used the service for quite some tim...
johntclinton
Nov 27, 2013Aspirant
Seems the problem was with the mt-daapd.conf file, which contained a lot of errors and wrong entries (primarily wrong database type, sqlite instead of sqlite3, and incorrect path to music files).
Once changed, it has all come back as before.
Many thanks for your pointers, Tony, and persistence in seeing this through to a solution.
John
John
