johntclinton
Sep 04, 2013Aspirant
Troubleshooting firefly on NV+ v2
Hi there, Following mdgm's and others advice (viewtopic.php?f=22&t=67954), I manually set up firefly and it worked successfully for quite some time. I had not used the service for quite some tim...
Mockduncan
Dec 30, 2013Aspirant
Tony, John - thanks for this. I had exactly the same problem. Thought my days of using command line interfaces and vi were 25 years behind me but I got there eventually. I did find multiple mt-daap.conf files and through trial and error changing each and re-booting got there in the end. I was going to try and figure out which edit did the job and report here to help others who must be having the problem so I renamed one copy of the the file and re-booted but it appeared again. No idea why and at this point I've decided to cut my loses before I do any damage (root access with someone who hasn't touched a command line for so long). Maybe if you know what directory the offending file resides in you could report it here. I also didn't manage to get it to write the log file either even though I specified it in the conf file.
Thanks again
Duncan
Thanks again
Duncan
