BieKee
Apr 23, 2018Aspirant
Try to rescue my data buy using second hand Nas
Hi, my Readynas NVX Pioneer edition seems to have given up. It looks to me like an OS problem. The webinterface shows less and less after each reboot, options disappear, the option that were still th...
- Apr 24, 2018
Your 4GB root volume was filled with 3.6GB of data from a backup job. This problem would have remained moving the disks to another chassis.
Your NAS is rebooting and you should be able to access your data now.
mdgm-ntgr
Apr 23, 2018NETGEAR Employee Retired
If the problem is with the disks or on the disks it'll remain moving the disks to another chassis. I've sent you a PM.
Also the NVX was discontinued several years ago.
If you must get a second hand unit running RAIDiator-x86 I'd get an Ultra/Ultra Plus/Pro as they're better models with 64-bit CPUs.
Even so the Ultra/Ultra Plus/Pro were discontinued about 5 years ago now.
There's no warranty or support for second hand units though.
It'd be much better to get a new x86 4-bay ReadyNAS e.g. RN424, RN524X and follow ReadyNAS: Migrating disks from RAIDiator 4.2 to ReadyNAS OS 6 (x86), but again that process working smoothly relies on the problem being just with the old chassis, not with the disks or what's on them.
