BieKee
Apr 23, 2018Aspirant
Try to rescue my data buy using second hand Nas
Hi, my Readynas NVX Pioneer edition seems to have given up. It looks to me like an OS problem. The webinterface shows less and less after each reboot, options disappear, the option that were still th...
- Apr 24, 2018
Your 4GB root volume was filled with 3.6GB of data from a backup job. This problem would have remained moving the disks to another chassis.
Your NAS is rebooting and you should be able to access your data now.
mdgm-ntgr
Apr 24, 2018NETGEAR Employee Retired
- BieKeeApr 25, 2018Aspirant
Many, many thanks, It is working again. I think it went wrong when i cancelled a backup job. I couldn't restart the job again (status stayed on cancelled) and then i decided to reboot via ssh, since restarting via the interface also didn't work anymore. Not shure if it would have been solved if had given it more time?
