Rimbalza
Aug 30, 2011Aspirant
Trying to configure iSCSI multipath
Hi, using Pro 6. I upgraded ti 4.2.19T4 to see if it does not crash after some seconds of heavy I/O with iSCSI. It continues to crash... Now I'm trying to setup multipath to see if it has some effe...
Grievous
There isn't anything to configure for multipath on the ReadyNAS, it's all client side. If you're using Windows Server, you need to install the MPIO feature.
Regarding the delete confirmation, you mentioned volumes I assume you mean the LUN? I just checked and with the entire UI in Italian, the message on screen still indicates to type "DELETE ALL LUNS" and typing that does work. The same goes for trying to delete an individual LUN, I get prompted to type "DELETE LUN" and that works as well. Since it sounds like you're seeing something different than I am, can you post a screenshot so we can see exactly what you mean?
