Rimbalza
Aug 30, 2011Aspirant
Trying to configure iSCSI multipath
Hi, using Pro 6. I upgraded ti 4.2.19T4 to see if it does not crash after some seconds of heavy I/O with iSCSI. It continues to crash... Now I'm trying to setup multipath to see if it has some effe...
Rimbalza
Aug 31, 2011Aspirant
Also trying to use MCS, adding the second connection results in error:
The target name is not found or is marked as hidden from login
The target name cannot be changed and is taken from the first connection, so it cannot be wrong.
EDIT:
I managed to have it work, even in a bizzarre manner. You MUST configure the target WITH access control, and use your initiator name.
MPIO is still not working, I put every device id I can imagine to generate, but it does not capture the PRO6 disk...
EDIT:
