Rimbalza
Aug 30, 2011Aspirant
Trying to configure iSCSI multipath
Hi, using Pro 6. I upgraded ti 4.2.19T4 to see if it does not crash after some seconds of heavy I/O with iSCSI. It continues to crash... Now I'm trying to setup multipath to see if it has some effe...
Grievous
Aug 31, 2011Aspirant
Have you opened MPIO in windows, switched to the discovery multi-paths tab, checked the "Add support for iSCSI devices" box, added it, hit ok and rebooted the server yet?
Regarding the access control list, you should always use the access control list since it's the only way different initiators are aware of eachother when connected to the target. If you didn't have access control enabled and had 2 clients connect and start manipulating data(since it's treated as a block level device, not a normal network file access protocol) it's a very quick way to end up with corrupt data.
