Rimbalza
Aug 30, 2011Aspirant
Trying to configure iSCSI multipath
Hi, using Pro 6. I upgraded ti 4.2.19T4 to see if it does not crash after some seconds of heavy I/O with iSCSI. It continues to crash... Now I'm trying to setup multipath to see if it has some effe...
Grievous
Sep 01, 2011Aspirant
I read the docs you linked, and I've personally configured MPIO for use with iSCSI on the ReadyNAS. You need to connect to the NAS, add the iSCSI support like I mentioned, and then make the second connection with the initiator while checking the enable multipath box on the connect to target page. You can't manually add device hardware ID's after enabling iSCSI support and in server 2008 R2 you should see "MSFT2005iSCSIBusType_0x9" on the MPIO devices page.
edit: By the way, as I recall data protection manager requires the use of dynamic disks, you should consider reading the following post and it applies to more than just the ReadyNAS:
viewtopic.php?f=126&t=46169
