NASNoob11
Mar 18, 2013Aspirant
Tweaking RAIDar's Java jre
Can someone maybe answer my question at: http://www.readynas.com/forum/viewtopic.php?f=129&t=63963#p388011 I've done this tweak twice now. It does seem to work fine! Just wondering what to do with...
Mar 20, 2013Guru - Experienced User
They are enabled on my system right now, and there are connections to readycloud.netgear.com, red.netgear.com, and a couple of connections into the amazon cloud. When I have a chance I'll disable them all, and take another look.
chirpa wrote: From what I've seen, even when 'disabled' they are still phoning home constantly. Try on a 6.0, not using any 'cloud' apps, and check 'lsof -i' on a console, readycloud.netgear.com is still connected constantly, even when setup wizard in an Offline mode.
ReadyCloud and the other cloud services are optional, and easily disabled.
