Tarv
Nov 22, 2014Aspirant
Two disks failed in array, will Acronis clone work?
Have a ReadyNas Pro 6 with a 6 disk X-RAID2 array. Disks 2 and 3 started reporting reallocated sectors a few days apart, and shortly after started reporting uncorrectable errors. I tried to replac...
Nov 23, 2014Guru - Experienced User
You can't swap out two dead drives at once. Even replacing one at a time will likely cause problems. Your best strategy is to do a fresh factory install with the new drives in place.
Basically the process is
(a) back up the configuration and save the data. Note any add-ons you have installed.
(b) do a factory reset on the NAS using the boot menu
(c) reinstall the add-ons
(d) restore the configuration
(e) restore the data.
You need to do (c) before (d).
