mike1615
May 20, 2012Aspirant
Ultra 2 Plus won't boot - support case #18604734
I've been running a ReadyNAS Ultra 2 Plus for about four months now without any problems. A few days ago I upgraded it to the new 4.2.20 firmware, during which I think the system rebooted successfully...
mike1615
OK, I double checked it and even when turned on in diskless mode my ReadyNAS is not visible in RAIDar, so it looks like I'll be waiting to hear from Netgear regarding my support ticket.
I also noticed that after the activity LED turns off (about ten seconds after power-up), there's a small green LED inside the left, front side of the chassis that flashes rapidly for about three seconds, then it's off for about six seconds, then the cycle repeats. It's not visible on the front panel, only if I peer in through the air vent openings on the left side or when the chassis is in diskless mode it is also visible through the front grill. I haven't been able to find any documentation on it, though, and I'm reluctant to disassemble the chassis to investigate further since it's likely to be going back to the manufacturer for a warranty exchange.
