mike1615
May 20, 2012Aspirant
Ultra 2 Plus won't boot - support case #18604734
I've been running a ReadyNAS Ultra 2 Plus for about four months now without any problems. A few days ago I upgraded it to the new 4.2.20 firmware, during which I think the system rebooted successfully...
May 23, 2012Guru - Experienced User
Bonnie was running on the NAS (using Super-Poussin's add-on), so the test was not done over the network. At that point I did not want to enable SSH access, so I was sticking with the community tools.
The file size is > 2x the memory (2.1 GB file, with a standard PRO-6 with 1 GB ram total) . I tested 1, 2, 3, and 4 inserted disks, and the results went up about as I would expect. The NAS uses xraid2, so it is RAID-5 with 4 drives installed.
I agree that IOPS is the appropriate measure for random small block performance (though that point is perhaps more appropriate for the NFS tuning thread).
Are you exchanging your NAS for another ReadyNAS, or going with a different brand?
