young1
Sep 23, 2011Aspirant
Ultra 4 Expansion Math - Correct?
Just got a new ultra 4 up and running. The volumes listed say the following... Configuration: RAID Level X-RAID2, 4 disks Status: Redundant RAID Disks: Ch 1 : WDC WD15EARS-00Z5...
TeknoJnky
Sep 23, 2011Hero
what raidiator version does frontview show?
did you start with all 4 drives in the device, or add them one by one?
if there is no data on it, you can try a factory default (system > update > factory default)
else, you may need to contact online support (post your ticket# in the first post thread title) and let them investigate.
normally its should happen automatically, or after a couple reboots.
