Avorill
Dec 25, 2012Aspirant
Ultra 4 Transfer speed very slow.
Hi all. I have a RNDU4000 with 2x3TB WD When I connect the NAS directly to my PC with CAT5 cable both the nas and pc is telling me the connection is 1GigaBit/s when I copy files to the nas the spee...
Avorill
Dec 28, 2012Aspirant
The speed is still to slow.
My nas is connected with 2 cat-5e cables to the router with 1Gbps connection
and if I connect a computer to the router with a cabal with 1Gbps connection
I only get about 47MB/s and 47 MB/s is 376 Mbps and that is not 1 Gbps so that is very slow.
And I get the same speed when I connect directly to the NAS with out any routers nor switch
1 Gbps is 128 MB/s.
And when I transfer BIG files throw wifi 5Ghz band and I have only 1 computer using that band with
I get the speed about 10MB/s and that is to slow
10 MB(s and that is about 80 Mbps
pls help me. and don't tell me I can't get any higher speed if so that I am foundering if the nas does not have any 1Gbps pan ports.
1 Gbps is 128 MB/s.
