Avorill
Dec 25, 2012Aspirant
Ultra 4 Transfer speed very slow.
Hi all. I have a RNDU4000 with 2x3TB WD When I connect the NAS directly to my PC with CAT5 cable both the nas and pc is telling me the connection is 1GigaBit/s when I copy files to the nas the spee...
Dec 28, 2012Guru - Experienced User
If you read this review: http://www.cnet.com/network-storage/net ... 013-2.html
You will see that they got 55 MB/s on writes. You are posting 47 MB/s which is pretty close. You should be getting faster speeds on NAS reads. Did you test that?
On WiFi you are getting normal throughput - I am not sure what you are expecting there, but 80 mbits/sec is a good speed for 802.11n @ 5 gHz Normally your WiFi thoughput is 1/2 to 1/3 the link speed.
