Avorill
Dec 25, 2012Aspirant
Ultra 4 Transfer speed very slow.
Hi all. I have a RNDU4000 with 2x3TB WD When I connect the NAS directly to my PC with CAT5 cable both the nas and pc is telling me the connection is 1GigaBit/s when I copy files to the nas the spee...
May 06, 2014Guru - Experienced User
11 MB/s (megabyte per second) is right => 88 mbits/sec. There are control packets as well as data packets on the wire, and some "dead" periods when one side or the other is waiting. So it doesn't quite add up to 100 mbits.
CMoney408 wrote: ...i know the switch is my weak point, i am getting about 11mb/s when transferring files to the NAS. is that about right? i feel like it should be much faster.
Large file reads at @ ~90 MB/s, large file writes@ ~60 MB/s. http://www.smallnetbuilder.com/nas/nas- ... l=&start=2
CMoney408 wrote: what would be the estimated speed bump if i replace the switch with a gigabit one?
Definitely worth the investment, unmanaged gigabit switches are very inexpensive.
First of all, that's the correct value for your network. Second, those are settings, not status.
CMoney408 wrote: Notes: both my computer and Nas show the MTU at 1500
